Post temp sender/wire/gauge
hello all,
upon turing on my ignition my temp. gauge heads all the way to the right and stays there...i figured it might be a short and grounded the green/black temp. sender wire against the engine block to check and the gauge pegged to the right again.
i replaced the temp. sender unit (hoping for an easy fix) but it didn't work. any ideas on where the short might be as well as where to get a decent wiring diagram...thanks in advance for the help...
dale
'69 912
Old 07-24-2001, 05:45 AM
912s's Avatar
Post
Try the Electrical links on Dave's site, he has a lot of great info....
Scot
http://www.hillmanimages.com/912/manual.html
Old 07-24-2001, 11:51 AM
Senior Member
Post
Hello
remove the cable from the sender while ignition on. tip it against ground and the needle shoud peg. remove it from ground and the needle shout fall down ( not sure )
If this isn´t doing your cable or the instrument are bad, then chak the instrument with a new cable ( You can switch the idiot light cable )
Shemats are under the 911 tech section. Time to sneak around.
Grüsse
Old 07-24-2001, 03:18 PM
Post
scott,
great wiring diagram...it should enable a number of projects this weekend, thanks a lot...
roland,
are you suggesting to just switch the wires (idiot light to temp sender)? it would be a great way to determine if the gauge is at fault...thanks
dale
Old 07-27-2001, 05:49 AM
Senior Member
Post
Hello
Yes they are very close on the engine and you can see the idiot light from the rear on the front you have acces trough the trunk or your MY has the pullable instruments ( big rubber visible behind the outher ring )
You can check your instrument and the wire with that.
Grüsse
Old 07-27-2001, 09:15 AM
