Alan.UK's Avatar
Wink best brake upgrade
Hi all,
Whats the best way to increase the front braking performance on my 67 912. I have replaced all the flexi's and upgraded to a daul m/c. But, what are the options with the front calipers, is there any upgrade which is a direct fit ? will later brakes and rotors fit or does the spindles/arms also need replacing.
I would like to increase the braking preformance but as with most things the budget does not stretch far.. and then theres the rear bearings, front shocks... on no the list goes on
Thanks in advance
Alan
Old 08-01-2001, 08:34 AM
Post
Hi Alan,
I made adapter plates for mine and installed sc rotors and calipers. I also added a willwood proportioning valve for brake balance. Works well.
Hope this helps, JMB.
Old 08-01-2001, 09:59 PM
Senior Member
Post
Hello
911 T (M) calipers with ventet 22mm discs.
Used from 1970 to 1977.
Grüsse
Old 08-02-2001, 11:24 AM
