-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Ticking/tapping noise (http://forums.pelicanparts.com/porsche-912-technical-forum/15708-ticking-tapping-noise.html)
Polo Red 08-19-2001 06:39 PM
I have an awful ticking (not a knocking noise)coming from the
engine of my '66 912. It has had the big bore kit upgrade and sat not running for a few years. I just bough it a few months ago and am in the process of restoring it. I would like to know what could be causing the noise? I think it may be either bad lifters or a flat spot in the cam? Please advise...this is really starting to drive me crazy!!!
Jones Low 08-20-2001 12:35 PM
First thing to do if the car has sat for a while is to do a valve adjust, tune-up, and change the oil/filter. Sounds like your 912 needs a carefully done valve adjustment.
Jones Low
69-912
josh912 08-20-2001 06:33 PM
Had a similar problem and it was a lifter. I tryed everything and nothing worked. So I lived with it for 6 months and the lifter finally wore in.
Joshua Harrison
1968 912 Coupe
www.geocities.com/jkh912
26 days till I'm reunited with my 912!!!!!!!!
