Weber Problem
Engine is out of the car, and I found that the small side plate of the Weber carb, and its gasket, has fallen off of the carb. Its fallen off the carb that is to the left when looking in the engine compartment. Before I go through taking off the carb and having to order a new gasket, I'd like to know what this plate and gasket do.
Efrain 68 912 p.s. All So Cal 912 owners, go to the 912 registry and find out about the October 6 So Cal 912 meeting. |
Efrain,
I believe that the plate covers an optional choke circuit assembly that is used on some vehicles. If you do not cover it, it will suck air under the butterfly. Later, JMB... |
Couldn't expained it better myself
------------------ Joshua Harrison 1968 912 Coupe www.geocities.com/jkh912 |
| All times are GMT -8. The time now is 02:38 PM. |
