Exclamation 911 into a 912e
can anyone give me advice on this converstion? i want to put a 912e engine and tranny into a 911 targa ..i would like to get ac in the car ..another question i had was anyway way to get more performance from the engine with the fuel injection i do not want carbs, how would hydrlic lifters work?
plus i heard about the dreaded thermals, anyway around these?
Old 04-20-2001, 05:33 PM
Send a message via AIM to JP Noonan
Post
1. The parts to put a 914 (912e) motor in a 911.
1. Engine bar, good luck finding one.
2. Thermal reactors, dunno, but you can buy replacement bypass pipes for $250.
3. Weld in engine mounts.
4. Heat exchangers, about $1200 apeice new (I think) used aren't real easy to find.
5. 923 tranny or a 915 with a smaller (unique) input shaft to fit the T-4.
6. Bursch 912e muffler $250
7. 914 tach, $20. One that dosen't bounce $100
8. 912e clutch cable $50 throttle cable $50
9. Tin ware, god help you... Maybe if you can weld you could bastardize something between 914 2.0L tin (hard enough to find) and some T-4 bus and 911 tin.
10. The motor only has 88-110 hp with FI so plan on a new rotary compressor ($250) and both a front and rear condensor set up with electric fans. The "tri-pod" belt drive system froma T-4 bus will work but I've had trouble myself finding one.
All in all, it would be much simpler to buy a good used 911 motor and add a Motronic or Haltech FI. imho
Old 09-09-2001, 09:00 PM
WFBowen's Avatar
Post
There's a thread here concerning adapting a type4 into a 911. Check it out-very informative with some links. JP covered it all in the above post, but I'll add to forget about the AC, as with 88hp, the car almost does a backflip when you turn on the AC at speed.
Old 09-10-2001, 08:52 AM
Senior Member
Post
Hello
Engine mount and header/exhaust can be made under usage from VW Bus parts or type 4 performance parts. Hughe market and selection in germany and the states is following up.
Also used parts are easy to get as most 912E where convertet to 911 or V8 engines.
If you have a 901 trany it is a bolt on while a 915 trany needs the 923 engine/trany parts for the clutch release.
I would not recomend hydraulic lifters.
T4 can be pushed up to 150 solid HP but this is cost extensive and you have to swap to CIS or Motronic.
Grüsse
Old 09-11-2001, 11:07 AM
Post
I have all the parts needed for the swap, as I'm parting my wrecked 912E!!!
Old 09-29-2001, 11:56 PM
