C. Clark's Avatar
Question 17" Boxster Wheels for a 69 / 912 ?
Hello
A friend has a set of 17" Boxster twist wheels he is selling cheap, can the wheels be used on my 69 912 ? What about spacers and fender clearance?
Thank you,
Chas
Old 10-24-2001, 07:10 AM
Post
I have 15x7's with 205/60/15's and that's about as big as you can go...I don't think the 17's would fit the wheel or style of the car.Good luck, Mark
Old 10-24-2001, 05:06 PM
Post
The 69s had wheel flares but I don't think the boxter wheels will fit. On my 68 I got an ocassional rub with my 205/60-15s. Also, I doubt, but I could very easily be wrong, that the wheels will fit on the hub, and you'll have to get a spacer. On a side not, what wheels do you have? I personally think that the Fuchs look the best on 68 and 69 912s and they're not that expensive, in comparison to some other Porsche wheels.
Joshua Harrison
Porsche owner at heart
Old 10-24-2001, 09:24 PM
C. Clark's Avatar
Post
Josh,
I am looking for a different look to my 912, at the same time I want a performance wheel, I currently run a set of Fuchs 6 x 15, they came off an old 911. There's little info out there on changing wheel sizes and such.
Thanks,
Chas
Old 10-25-2001, 07:22 AM
Efrain68912's Avatar
Post
I have seen 16" Boxter wheels on a 914, so maybe those will fit. I've never had tire rub, I have 6 and 17 x 16 inch fuchs on 205 55 16 tires.
Efrain
68 912 Coupe
Old 10-30-2001, 09:34 AM
C. Clark's Avatar
Post
Hello,
I just got a set of 6" X16" Boxster alloys, I'm running 205/55/16RZ tires, nice look and a easy upgrade. I had to use 1/2" spacers to get within 2mm of the original tracking/ geometry of the car. So far so good.
Thanks,
Chas.
Old 10-30-2001, 10:01 PM
