Question Air/Mixture Screws
Please advise:
On a 69 912 with split shaft Solex carbs..which way do you turn the screws to lean (add more air)the mixture, in or out??
The manual does not say.
To make it easer to turn the screws, there is little room for a screwdriver, I put a 5/16" ID steel locking collar on each mixture, now I can turn them easily by hand..no more screwdrivers. They act as big knobs and the set screw is the pointer so you can count the rotations.
Cost..$2.50 for four at local hardware store.
Thanks,
Ron
Old 11-01-2001, 01:40 PM
Post
In to Lean (they rhyme!!!!), out to richen
Joshua Harrison
Porsche owner at heart
Old 11-01-2001, 07:42 PM
