Post license plate lights
OK guys,on my 69 I have all my lights working except the lights over the back plate. I have replaced the fuse, replaced the lights, cleaned the connectors......so any ideas???
Old 11-05-2001, 04:50 PM
Post
Hi,
I had the same problem and did everything you did. I ended up checking the wires with a meter and found things to be OK. It turned out that the lights that appeared to be fine would not work.
Oxidation had taken it's toll and I finally bought a bunch from ebay and the swap meet until I found two that worked.
Good Luck, JMB...
Old 11-05-2001, 05:59 PM
Post
Check for missing wire going to the voltage regulator. Mine didn't work for over a year and after hours of messing with the wiring I found a wire by the voltage regulator not connected. Connected it and Whalla! Instant license plate lights!
Joshua Harrison
Porsche owner at heart
Old 11-05-2001, 09:40 PM
