Send a message via AIM to allshowauto
engine oil leaks from everywhere but valve covers
Can you tell me if there are any band aid cures for the leaks? I have done the 20-50 and replaced the valve covers. The problem is that the heater is blowing the smoke into the cabin and killing me. I am almost out of winter, but ..
Old 04-23-2004, 11:56 AM
abit off center
cgarr's Avatar
I had a leak so bad like you before my rebuild i had to slow it down until I got it apart, Mine leaked real bad around the cylinder head bolts and onto the exhaust,, there the bolts inside the valve cover that the rocker assem bolts too. I took the rockers off and cleaned up around the bolts and sealed them with silicone, it worked, otherwise you have to remove the head and put new o ring seals under the bolts,, I know others will not approve but it did stop the leak until I got it apart.
Craig
______________________
Craig
G2Performance
Old 04-23-2004, 02:23 PM
C. Clark's Avatar
Replace the leaking seals and gaskets.....no free lunch.
Chas.
69/912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 04-23-2004, 04:59 PM
