-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   replacing venturis on a weber 40 idf (http://forums.pelicanparts.com/porsche-912-technical-forum/161648-replacing-venturis-weber-40-idf.html)
rexsole 05-05-2004 07:54 AM
Does anyone know how hard it is to change venturis on this model? Also, how hard is it to get 32 mm venturis. I have carbs with 28mm and I need 32 to use with the 912 engine I have.
cobra-6 05-06-2004 10:28 AM
It's easy, just a couple of set screws hold them in place.
Take a look at a parts diagram
Weber diagram
TonyB 05-07-2004 09:29 AM
www.aircooled.net sells almost every part of the Weber carb you could ever need. Drop John Connolly a line and tell him what you have and he can even get you close on the jetting too.
