Beauty Turns Beast @ 5000RPM
Oh, am I back on the road ..... one year and a complete engine rebuild later...... I now know the true nature of the lil' beast. The bratty b.. ch becomes a howling warrior princess when you let her go to the redline. I've owned this '67 for over three years and always suspected it was designed to be run as a racer, but until the rebuild it was a dud. Right now, and I know cars like the 912 change like the New England weather, it is running factory new perfect. It's now at 1700cc's with a .050 dist and webers.
Thanks to the rebuilder Jeff at Labelle and Leitner in Greenfield Ma. A real mechanic.
Jim in Ma.
Old 05-21-2004, 07:41 PM
Hoffman912's Avatar
ah yes.. five grand fun
make sure you break in the rebuild correctly though, so that you dont break her instead....
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 05-21-2004, 10:51 PM
There are various schools of thought on break-in. For the first 400 miles I was careful to drive under 2800 rpm with a cold or cool motor, varied the speed, and kept it under 4000 rpm. I then let the rebuilder change the oil and reset the valves.
Now if I had the $$ for a paint job ......
Old 05-22-2004, 04:13 AM
