-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   case assembly (http://forums.pelicanparts.com/porsche-912-technical-forum/165181-case-assembly.html)
bigbrotherjohn 05-28-2004 10:16 AM
case assembly
when assembling your case do you use thread locker on the case bolts or not. thanks
C. Clark 05-29-2004 05:33 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=151268&highlight=case+a ssembly
Chas.
69/912
cgarr 05-29-2004 07:24 PM
The only thing I used locktite on was the rod bolts and the flywheel nut. After reading the above post, your guess is as good as mine, pal nuts, safety wire?? Just torque it right and you will be fine,
Craig
Morrie 06-17-2004 12:12 PM
I guess you are either a fan or you are not, but the HCP Research videos on engine assembly do an outstanding job of walking you through putting the engine together bolt by bolt. We actually had the VCR out in the garage and built our motor right along with Harry. Lots of good tips.
Just my humble opinion....
Morrie
