FenderGuy's Avatar
ac in a 912e?
has there been any recent ac advances for this? looking at a 912e no ac though
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 04-20-2004, 01:39 PM
COLDBASS's Avatar
What type of advances? You could always add the under the pan condensor and switch to a rotary vane style compressor. I still have the original York.
923/912E (2.1l OEM EFI
'99 F150 4x4 Chipped (who cares)
LLVL in the LBC...
"Long Hoods Rule"
"RICE - The Breakfast of Champions"
Old 04-20-2004, 05:58 PM
eki912's Avatar
Stan Wilder TX , has done some major improvements on his 912E.
I am going to do some small things , taking old YORK out.Replacing it with a SANDEN.Should be a major improvement.
What advances do you mean?
Erkki
Old 04-21-2004, 08:52 AM
FenderGuy's Avatar
i guess none just wondering if there had been any advances in coooling these cars
Frank
Old 04-21-2004, 01:45 PM
COLDBASS's Avatar
Smile
Still not sure if I understand your question, however, I am killing 2 birds with one stone. I have attached 2 - 5.5" pull type fans to the grill condensor. This adds in sucking in air to the engine compartment. Additionally, this air is passed thru the condensor with aids in dissapating the heat off the coils...
Hope this helps...
LLVL in the LBC...
"Long Hoods Rule"
Old 04-21-2004, 03:24 PM
eki912's Avatar
This "add on" fan thing sounds too easy.....
Does it really make a noticeable difference ? Naturally I do understand when car is stationary and idling there is not much airflow through the grill.
If that did help , I might do the same thing.....
Always looking for improvements !!! ( that are easy and cheap to do )
Erkki
Old 04-22-2004, 05:23 AM
COLDBASS's Avatar
Eki
Last summer during the triple digit days, with my ac on, my temp guage did not rise above approx 75%. The fans are wired into the York compressor circuit, so when I flip the ac on both the interior and engine are cooler...
Regards,
Bob
LLVL in the LBC...
"Long Hoods Rule"
Old 04-22-2004, 08:50 AM
eki912's Avatar
OK , I have thought about the same thing.
Just did not do anything , because I thought that this "fix" is too simple to work !!!! So maybe I should , and I will.
What fans are you using ?
I would imagine that with the new Sanden compressor and maybe the additional fans , AC should work better than ever.
Erkki
Old 04-22-2004, 09:29 AM
COLDBASS's Avatar
Eki
I bought the fans from Mocal/BAT Inc in Florida.
http://www.batinc.net/
Kinda pricey, you should be able to find some alternate cost effective units...
Well, since I installed the rear pop-outs I use the ac less...
I recall reading an article regarding the HP drain from the York. The calc's were done using a dyno...approc 7-10 HP loss IIRC...
Good Luck
Bob
LLVL in the LBC...
"Long Hoods Rule"
Old 04-23-2004, 03:38 PM
eki912's Avatar
what happened to your raintray ?
how did you deal with the fans and the raintray?
Eki
Old 04-30-2004, 01:48 PM
COLDBASS's Avatar
No raintray, the car came with factory a/c (engine lid condensor).
I mounted the fans onto the condensor. I have a pic somewhere...I'll look for it...
Bob
LLVL in the LBC...
"Long Hoods Rule"
Old 05-01-2004, 06:47 PM
this is a very reasonable upgrade, this 82 911 SC has new compressor and other ac parts on strong running car ...
1982 911SC coupe for sale
Old 06-05-2004, 11:00 AM
porschedreamer's Avatar
Send a message via AIM to porschedreamer Send a message via Yahoo to porschedreamer
COLDBASS: any PIX?
http://porsche.edbot2000.com
Old 06-06-2004, 01:02 PM
COLDBASS's Avatar
LLVL in the LBC...
"Long Hoods Rule"
Old 06-06-2004, 05:05 PM
COLDBASS's Avatar
Please no comments about the NAAASSSS bottle....
LLVL in the LBC...
"Long Hoods Rule"
Old 06-06-2004, 05:06 PM
very DOPE!
*drool* 912 with a/c *drool*
Old 06-06-2004, 08:25 PM
COLDBASS's Avatar
LOL, its actually the Accusump reservoir
Old 06-07-2004, 04:36 PM
hmmm....
does anyone have a "parts list"/diagram for installing an a/c on a typ4 that didnt have it before?
a blow by blow:
what parts needed
where we can possibly adapt an existing part.
where to run the lines
gosh a concise "guide" on installing an AC system on a car that didnt have it before would be sooo cool
Old 06-07-2004, 06:54 PM
COLDBASS's Avatar
Hmmm, you may wish to call Performance Aire in Anaheim, CA. They have done a few "E"s and may have some info...
Good Luck...
LLVL in the LBC...
"Long Hoods Rule"
Old 06-08-2004, 05:50 PM
COLDBASS: I couldnt find Performance Aire. hmmm? by the way.. has anyone ever seen Vintage Air's implementation of A/C?
Old 06-09-2004, 05:48 PM
