mrandall's Avatar
Question Help with '76 912E Oil Cooler
Hi! Since this is my first post, let me start by saying, "Great site!"
I have a completely stock 912E, and the oil cooler is leaking (just a bit) . I have a new cooler, tools, and time. I am planning to drop the engine in a couple of weeks. Is there an easier way? Are there any gotcha's?
Mike Randall
1976 912E
Old 08-08-2004, 07:42 PM
COLDBASS's Avatar
Welcome aboard and welcome to our world...I've never performed this task. I think that there is no easy way...
Bob
923/912E (2.1l OEM EFI
'99 F150 4x4 Chipped (who cares)
LLVL in the LBC...
"Long Hoods Rule"
"RICE - The Breakfast of Champions"
Old 08-09-2004, 11:09 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
You can do it with out removing the motor.You need to remove the tin that is the rear peice. Then remove the fan and then the blower housing. The oilcooler will be right there. fairly easy job It will just take some time.
Old 08-09-2004, 06:51 PM
mrandall's Avatar
Smile
Thanks! You just made my day!
Mike Randall
1976 912E
Old 08-10-2004, 07:53 AM
How did the job go? Was it just a bad seal or was the cooler itself leaking?
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 08-26-2004, 09:50 PM
mrandall's Avatar
Lightbulb
I hope to find out this weekend. Being the retentive type, I wanted to wait until I could borrow a digital camera to capture the magic. Then I will be able to post the results and process for anyone else that would care to tackle this job. I will keep you posted. Thanks again for all of the support.
Here is my new car. I bought from the 2nd owner with 60K original miles.
Mike Randall
1976 912E
Old 08-27-2004, 01:52 PM
mrandall's Avatar
Does anyone know if you can replace the bearing on the "driveshaft" that runs the belts (comes off the fan) on a 912E. I have pulled the unit (on the way to the oil cooler) and have mild bearing noise. I have access to a 12 ton press, but I don't want to press off the pulley / driveshaft assembly until I know that I can replace the bearing.
If it can be replaced, what is the bearing number / make?
If anyone has done this, advice is appreciated.. Thanks
Mike Randall
1976 912E
Old 08-29-2004, 08:09 PM
COLDBASS's Avatar
If you are not running a/c then I believe that they are the same part as the one on the 914 so they should be available. I run a/c, got PO'd at the lack of parts, and the stupid asses...came up with an alternate solution that eliminates the drive shaft assy altogether...IIRC , I've posted pics here, STF and 912 board....I think...
LLVL in the LBC...
"Long Hoods Rule"
Old 08-30-2004, 06:24 AM
FenderGuy's Avatar
damn i cant seem to find deals like that
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 08-30-2004, 02:30 PM
mrandall's Avatar
Wink
Well, In between hurricanes (FL) I have managed to disassemble the car to the point where I could change the cooler. Here is a quick picture of the disassembly. I will hope to put back together over the next weekend or so, depending on the "honey-do" list.
Thanks again!
Mike Randall
1976 912E
Old 09-17-2004, 06:24 AM
COLDBASS's Avatar
I see that the a/c compressor was upgraded. Interested in seeing the bracket, is it the stock unit with an adapter plate...please show pics...
Bob
LLVL in the LBC...
"Long Hoods Rule"
Old 09-17-2004, 06:45 AM
