-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912 machining Specs (http://forums.pelicanparts.com/porsche-912-technical-forum/176153-912-machining-specs.html)
pelliott 08-05-2004 11:58 AM
912 machining Specs
I'm rebuilding a one-off unique engine that uses a 912 crankshaft. I need to know the specs for the connecting rod journals. ( The housing bore size and the shaft size).
Thanks Much!
