crank case alloy?
Does anyone know what alloy was used to cast the 912 cases. I want to know in order to be able to weld a crack in the case. thanks.
Old 08-29-2004, 06:35 PM
abit off center
cgarr's Avatar
its just Alum dont know what alloy, 6061, 2024 5050? I welded mine with some alum rod laying around the shop, worked well, just get it good and clean.
cg
______________________
Craig
G2Performance
Old 08-30-2004, 05:14 PM
did you take any precautions when welding in order to avoid heat cracking.
Old 08-30-2004, 06:45 PM
abit off center
cgarr's Avatar
no, it was a small spot that had to be welded, these cases are very good strong alum, its not like welding cheap pot alum or cast iron. I had cracked my third peice when threading in my alum fitting for the full flow oil so I just welded the fitting right in.
cg
Craig
G2Performance
Old 08-30-2004, 06:51 PM
