Does anyone know how to polarize the generator when replacing the regulator.
Thanks Mike
65 912 69 912 |
Before replacing the fan belt, connect the battery lead to terminal D+/61 at the regulator for a few seconds. The generator should run in the same direction as engine rotation.
Duke,
You are saying to take the lead that normally connects to the B+ terminal at the top and touch it to the D+/61 terminal.
65 912 69 912 |
Mike, been out of town. Yes that should work. I guess you have it by now.
B+ to D+. I have even used this once on a used one that somehow flaked out..... Only works on the mechanical ones though, I believe there are solid state versions out there too and I am not sure how this effects them.....
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe" Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S |
