| Registered Join Date: Oct 2004
				 |  912 regulator
			Does anyone know how to polarize the generator when replacing the regulator. Thanks Mike
				__________________ 65 912 69 912 | ||
|  10-14-2004, 10:12 AM |
| Registered Join Date: Nov 2000 Location: Redding,CA USA
			Before replacing the fan belt, connect the battery lead to terminal D+/61 at the regulator for a few seconds.  The generator should run in the same direction as engine rotation.
|  10-14-2004, 11:02 AM |
			Duke, You are saying to take the lead that normally connects to the B+ terminal at the top and touch it to the D+/61 terminal.
|  10-15-2004, 08:54 AM |
			Mike,  been out of town.  Yes that should work.  I guess you have it by now.
|  10-19-2004, 06:43 PM |
| Registered Join Date: Nov 2001 Location: Austin, TX
			B+ to D+.  I have even used this once on a used one that somehow flaked out..... Only works on the mechanical ones though, I believe there are solid state versions out there too and I am not sure how this effects them..... Morrie
				__________________ 68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe" Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S | ||
|  10-21-2004, 11:00 AM |
