LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
mrandall's Avatar
Cool Vac lines on the distributor
All,
I have a 76 912E with original Fuel Injection. I was looking at the vac lines that hook to the distributor, and could not be sure that they are correct. Can someone confirm that the setup below is correct. (There are actually two ports on the throttle body, the one not pictured goes to the back of the distrubutor pot)
Mike
Mike Randall
1976 912E
Old 10-18-2004, 12:35 PM
Re: Vac lines on the distributor
Mike:
I also have an original (40K miles) 912E with all the orginal parts and I have been doing an investigation on the correct vacuum hose arrnagement since some one had plugged one line and put two Tees in others. Appears to me that the hose you show from the right side of the distributor to the left side of the throttle body should have a T in it with the other side of the T runing to the EGR valve. What source of vacuum is your EGR currently connected to?
Originally posted by mrandall
All,
Mike
Old 11-12-2004, 04:39 AM
