Hbrand
hbrand's Avatar
Mystery Porsche ???
I have a strange Porsche and would like to get some comments what this porsche is>
engine number 900836, webers, oil fed camshafts
number stamped next to fuel tank 354493
paint code 68-6601-G
5 speed 901 transmission
short wheel base car
front sway bar
no flared fenders front and rear
long horn grilles with 2 mounting screws
euro headlams with small chromring, bulb type
alu bumber trim with rolled rubber trim
front vented disks, rear non vented
chrome vent windows with chrom handles
7200 redline
200kmh speedo
other gauges all euro type
glove box door griphandle all along top
locking brushed alu ignition lock
brushed alu dash trim
button less dash top
wood steering wheel without rivets
black headliner
thanks for helping
harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 12-19-2004, 10:32 AM
Duke's Avatar
According to my info you have a 67 912 body with a 65 911 engine. Paint code 6601 is a 66-67 slate gray.
Old 12-19-2004, 11:04 AM
Hbrand
hbrand's Avatar
mystery porsche
what about the no flared fenders??
have seen 1965 porsches with flares??
Could it not bee that this is an earlyest porsche 911 with 921 vin number - ?
thanks, harold
Cheers
1969 Mercedes 280SL
Old 12-19-2004, 03:31 PM
Hoffman912's Avatar
un.. swb cars dont really have fender flares...
take pics. let us look at it to know what youre talking about.
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 12-19-2004, 06:28 PM
Hbrand
hbrand's Avatar
mystery porsche
will post pictures on monday.
thanks, harold
Cheers
1969 Mercedes 280SL
Old 12-19-2004, 06:33 PM
Hbrand
hbrand's Avatar
Cheers
1969 Mercedes 280SL
Old 12-20-2004, 06:10 AM
Standard 912 body.
Old 12-20-2004, 09:05 AM
Duke's Avatar
Fender flares did not appear until the lwb 69 models. The engine number & chassis number tells it all. Many older cars have been modified for various reasons, some due to body damage??
Old 12-20-2004, 09:18 AM
I guess a Slab Side 67 or 68 SWB.
Not sure if it started life as a 912 or 911 since the engine and tach appear to be 911 and could have been swapped in.
The 68's had unique inside door panels.
If it was a 67 or 68 912 than you should see evidence where the center 912 motor mounts were removed and the rear 911 motor mounts were added for the 6 cylinder.
-Don B
Top of the line 911 in 1966.
Old 01-27-2005, 11:48 AM
bmwloco's Avatar
I'm guessing '67 or early '68. Looks like the door handles are push button. Officially '67 was the last year for that due to roll over safety issues.
Old 01-27-2005, 12:12 PM
I see he says he has this one:
"1968 912 Coupe w/ Sunroof"
which sounds suspiciously like the pics.
Of course that engine is not a 912.
-Don B
Old 01-27-2005, 12:23 PM
Jerome Ryals's Avatar
Its definitely not a '68, no side marker reflectors, the green gauges and covered headlights make it earlier.
Old 01-29-2005, 12:53 PM
