Question Brake Master cylinders (single/dual?)
Will a dual circuit master cylinder work/fit without problems in my 66 912?
I would opt to have dual circuit if this is feasible...
thanks,
Erik.
Old 03-30-2001, 11:00 AM
Efrain68912's Avatar
Post
The dual master clylinder will bolut up fine to your car. The only thing you will have to change is go to a shorter brake pedal pin (the pin that goes into the master cylinder from the brake pedal), as the one from your 66, which is for the single master cylinder, is longer.
Old 03-30-2001, 10:28 PM
bump
________________________________
'67 912
'89 944 S2
'87 944 Turbo
'82 MB 300CD
Old 04-18-2005, 09:06 AM
Jerome Ryals's Avatar
Pretty sure you will need to replace the brake fluid reservoir also when converting from single to dual.
Old 04-18-2005, 09:29 AM
