Send a message via Yahoo to clinton
Best place to put jack stands
What do you guys think the best to put stands under the car to get the front suspension out is? Also you guy have any tips on anything I need to look out for like adjustments or anything?
Visit my site www.orderdairy.com/Porsche/
Old 04-30-2005, 10:42 AM
The pinch welds inboard/aft of the wheel wells. Be careful. Check things several times before crawling around under there.
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 04-30-2005, 06:39 PM
Thanks that is where I was thinking to put them, Is there some place forward of the wheel wells I could put some for backup and still allow for the pan drop
Old 04-30-2005, 09:19 PM
Jerome Ryals's Avatar
I place a 2 x 6 board long enough to pass all the way under the car and cut a notch so both of the pinch welds (either side) have a groove to fit down into. Jack stands of couse go under the board.
Old 05-01-2005, 01:13 AM
The only problem with thin wood, in my opinion, is it's tendency to split/crack under pressure. If you used an old railroad tie, that's one thing. But lumber yard dry pine splits too easily for me to trust my noggin with it.
Old 05-01-2005, 12:32 PM
C. Clark's Avatar
Use two 2x4's or 2x6's screwed or nailed together if 1 makes you nervous. Personally I've used the 2x4 system front or rear with no problems, move the stands about 12 inches in from the body edge for better support if possible.
Chas.
356
912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 05-02-2005, 05:53 AM
