-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   timing (http://forums.pelicanparts.com/porsche-912-technical-forum/229359-timing.html)
microfone 07-03-2005 09:19 PM
timing
Hi! i just finish to fix my new pertronic kit and i want to know the max advance i can put on .
thanks to taketime
Mic
microfone 07-09-2005 04:28 AM
28 at 2700
mic
Morrie 07-11-2005 04:23 PM
set it to a max advance of around 30 to 32 degrees, it should hit max around 3500 rpms, but don't worry about the RPMs, just the max advace. What disty are you running? Please do not say 009.... :(
microfone 07-11-2005 04:30 PM
Yes Morrie,i have a 009. It's a problem???
thanks, Mic.
cgarr 07-11-2005 08:12 PM
I dont think you can get max of 32 degrees out of a 009, if you do the advance at idle would be way too much? Try to find an 050 or 032 dizzy.
Craig
