| Registered Join Date: Apr 2003 Location: Cornelius, OR
				912E Clutch Cable Replacement
			Ok, so I need some help from the experts out there. What is the physical difference between the 912E clutch cable and a 911 clutch cable from a '76 model year car? I can not seem to locate a distributor for the OEM 912E part number and wondering if the 911 equivalent would do the same.  Thanks in advance, Britain
				__________________ '69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- | ||
|  07-12-2005, 03:03 PM |
| Registered |
			Britain: The 912E and 911 cables are different, and, as you know the 912E cable is getting hard to find. Try www.masterautoparts.com and search part: POR039773 I have no affiliation with them, but ordered once and was very pleased. Be prepared for a high price, as these particular cables have always been expensive compared to all the other Porsche clutch cables. Good luck, Bill. | ||
|  07-13-2005, 08:09 PM |
