-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912 Engine Reassembly Question (http://forums.pelicanparts.com/porsche-912-technical-forum/246686-912-engine-reassembly-question.html)
cameroncole 10-18-2005 12:32 PM
Hello,
I have cleaned up my donor engine and have powdercoated the tin. Now, I would like to replace a few of the engine gaskets -
1. Timing cover
2. Oil Pump Cover
3. Generator Stand
4. Oil Filler
5. Front Engine Seal
6. Rear Engine Seal, Gland Nut and washer
7. Oil Tube Seals?? Not sure - probably should. Will I ruin the old tubes?
What gasket sealant material (if any) should be used on the above? Spray on ? RTV?
Thanks,
Frank
C. Clark 10-19-2005 05:29 PM
I'm old school and I use a little grease on gaskets and seals, I have used silicone on push rod tubes....they didn't leak.
Chas.
356
912
