915/67,912 install
How do I fix the axle shaft differences and any other problems with this conversion?
Lars
Old 03-17-2006, 07:28 AM
C. Clark's Avatar
I'm not sure what you mean but try these guys...http://www.912bbs.org/
Chas.
356
912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 03-17-2006, 04:35 PM
I dont know if the 915 is that much longer than the 901. Either way it should not be that hard to weld something onto the trans brace. You have to keep the same bananna arms (69 up have longer arms, LWB). I would check the VW sites because its pretty common for buggy builders to lengthen/shorten their drive axles. Any drive shaft place should be able to fab something if you need somthing special.
Old 03-24-2006, 08:59 PM
