915/67,912 install
How do I fix the axle shaft differences and any other problems with this conversion?
Lars |
I dont know if the 915 is that much longer than the 901. Either way it should not be that hard to weld something onto the trans brace. You have to keep the same bananna arms (69 up have longer arms, LWB). I would check the VW sites because its pretty common for buggy builders to lengthen/shorten their drive axles. Any drive shaft place should be able to fab something if you need somthing special.
| All times are GMT -8. The time now is 02:18 AM. |
