-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Charging problem (http://forums.pelicanparts.com/porsche-912-technical-forum/273446-charging-problem.html)
jac912 03-25-2006 03:48 AM
Charging problem
After jump starting my '67 recently due to a completly dead battery I get no charge and the amp light stays on. Replaced the battery which was due and re-polarized the generator ... maybe. Should't the gen spin when polarizing? BTW Stoddard qouted me $325 for a Volt Reg ... and they have none ....
Jim in Ma.
robfike 03-25-2006 10:51 AM
The generator does not spin when it is Polarized, or "Flashed".
jac912 03-26-2006 03:54 AM
Yes .. just the regulator and also quoted $120 for an oil temp sender ( should be $25) .. which they don't have either. I'll retest everything today ... if it gets above 40 degrees.
Jim in Ma.
jac912 03-28-2006 03:36 AM
Found the regulator thru a local shop with good supply connections for $105 retail. Took the old reg apart and cleaned the contacts ... will try again tonight. Gen spins nicely with B+ to D+ so don't think it is the gen.
