-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Floats for Solex 40 P11 (http://forums.pelicanparts.com/porsche-912-technical-forum/276726-floats-solex-40-p11.html)
kry59 04-11-2006 09:12 PM
Where can I get these? I Disassembled one carb tonight and found that the float has fluid in it. Whoever worked on it before used a caulk of some sort to seal the edge of the top to the bottom of the float. If I can't get these, what type of sealant can I use to do the same until I find some.
ediamiam 04-11-2006 09:53 PM
some places to check out on your journey..
harry bieker rebuilds carbs, may have the floats you need. he also sells the float gauge for setting float level. will at csp - supplies parts for the 912. the 912 bbs - good place to hang out, and pose your questions. more likely to get better response than here. partsheaven is a porsche recycler. there is not one-stop shopping available and you need to check out multiple sources typically.
http://www.biekerengineering.com/
http://www.classicandspeedparts.com/s/
http://www.912bbs.org/
http://www.partsheaven.com/
