Holy Sparks Out Of The Carb Bat Man!
Hey guys. So I got this 912 that had a broken valve adjusting screw. I replaced that screw and adjusted the valves. Then it was still running poorly so I took apart the carbs and they were nasty. Cleaned and rebuilt them, reinstalled them and now I have sparks coming out of a carb barrell. Its the cylinder on the passenger side near the firewall. Now I installed new plugs also. So what could it be? I set timing at 28 degrees, should I go to 30 degrees? Could I have adjusted the valves on that cylinder wrong? Just for reference, I adjusted the carbs by screwing the big roung plastic knobs on the base of the carbs in all the way and then out 1 full turn, when I did 1.5 turns out as specified there was a ton of black smoke. So what do I do to stop the sparks from occuring and have it run correctly?
Old 04-14-2006, 09:52 AM
flames back thru the carbs usually indicate a timming problem however a lean carb mixture can do that as well if the engine is cold. A grossly misadjusted ( or bent ) intake valve that is not seating properly could also be the culprit. Spark `crossfire` inside a dirty distributor cap could cause the same situation.
If the carbs were as `nasty` as you suggest I would clean out all the idle jets..... it doesn`t take much to clog one........... which could make adjusting the mixture screws damn near impossible.................. A lean idle setting will cause popping back thru the carb at idle when the engine is cold.
good luck, Jeff
Old 04-14-2006, 10:32 AM
Well could a leaking intake gasket be the culprit? I think I have that condition also as I had to cut a gasket out of a sheet of pond liner that I was missing and its thinner than the rest of the gaskets?
Old 04-14-2006, 11:26 AM
If you have an intake air leak you will be chasing a good idle....both speed and mixture. Jeff
Old 04-14-2006, 06:35 PM
Nige-912E's Avatar
that would certainly be a good place to start
As Jeff says
I'm also getting popping/backfiring up through my carbs, although mine are like new. Most likely timing or as Jeff says a lean mixture. I have the car booked in at a rolling road to get the carbs and everything setup just so. This should solve my problems.
You should never use pond liner on a Porsche It might also melt when it gets up to temp!! That will give you even more problems
Old 04-15-2006, 09:14 AM
