912E Smog Pump Rubber Pulley damper
I am looking for a source to buy the failed rubber damper, (bushing??) on my 912E smog pump pulley bracket assembly. Any help in finding a source would be greatly appreciated.
Thanks for the help
Andy
Old 12-05-2006, 08:20 PM
WFBowen's Avatar
Andy:
Is it part of the "W" assembly seen below?
Old 12-06-2006, 09:53 AM
It is on the left side of the shaft which you have indicated in the iso. I ordered that same part "W" from Stoddard and it did not come with the rubber damper which is at the end of the shaft.
Andy
Old 12-06-2006, 06:19 PM
WFBowen's Avatar
Andy:
Only suggestion I have is to take your part to a local VW dealer & tell him you need the rubber isolator for it - lots of VW vans with TypeIV motors used this same setup.
Good luck,
Bill.
Old 12-06-2006, 08:19 PM
Nige-912E's Avatar
I have the whole assembly somewhere, if you want it?
Old 12-08-2006, 01:54 AM
Bill, Thanks for the tip, I guess it wouldn't hurt to try, I've tried most everything.
Andy
Nige-912E, Does the whole assembly have the rubber damper attached to it? What is the condition of the rubber damper? What is the cost for the whole thing and/or just the rubber damper?
Andy
Andy
Old 12-09-2006, 07:14 PM
Nige-912E's Avatar
Hi Andrew
I'll have to dig it out and check, I removed it from my car when it was imported in 2000 so I haven't looked at it for 6 years.
Will report back shortly
Old 12-10-2006, 12:29 PM
Andrew-
Check my post for the '912e parts & peices' for the part you are looking for.
Phil
Old 12-22-2006, 09:59 AM
