Fan Belt Replacement
I recently purchased a 67' 912 targa. The fan belt broke and i need to replace it. What is the correct tool to use, i think it is missing in my tool kit. Thanks for your assistance.
Brian
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 11-27-2006, 10:40 AM
912UK's Avatar
looks like no one has replied..
it';s easy easy easy
have a look on ebay there are some generator spanners going for about $30 have a word with these guys ( pelican ) as they seam to be making them again.. in black oringal ones are chrome..
you can use a big shifter..
put a flat bladed screw driver in the top pully slot ( you will see this as a notch ) this shoudl then hold the top pully in place..
Then un do the huge nut and you can take the half of the pully off and then get to the belt..
15mins job..
BUT how you set it is the key..
you want about 3/4" play in the long part fo the belt
and to do this it's done by adding or removing shimms
Too many cars too little time..
Old 12-17-2006, 10:29 AM
Green 912's Avatar
A little to add. Keep all the shims on the gen shaft. Any shims that you remove from in between the pully halves you need to put on the outer pully before you put the 36mm nut back on.
Old 12-20-2006, 01:26 AM
