-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912 Engine serial number (http://forums.pelicanparts.com/porsche-912-technical-forum/417496-912-engine-serial-number.html)
HOjer 06-30-2008 07:32 PM
Hello
I can't find the serial number the normal spot? It says Made in Germany and looks original. See attached picture below.
Any help would be great. The car is a 1968 and I hope the engine is the same.
Thanks.
HOjer
http://forums.pelicanparts.com/uploa...1214883141.jpg
Jaems 07-02-2008 10:04 AM
Generally a factory replacement motor did not have a serial number. Also the rear motor mount is not correct for a 68. This one was used in the 65 and verily early And the dog house is for a 65-67 motor.
66.http://forums.pelicanparts.com/uploa...1215021662.jpg
The 68 motor is very dirty. However, you can see what you are missing on your motor
http://forums.pelicanparts.com/uploa...1215021681.jpg
j.hall 07-02-2008 06:49 PM
'68 engine
Jaems,
What is the item between (and slightly above) the oil filter cannister and the coil in your picture of the dirty '68 motor?
thanks, joe
Jaems 07-03-2008 10:07 AM
That has to do with the emissions for 68. It was required for 68 only. There was also a air pump on the driver's side which has been removed from this motor.
Also the stamps on the case will be 616/36 on the 68 and a very late case 616/39. It looks like you have the early small generator and that would mean that you had a early 68 motor. They went to a larger generator with the 616/39 motor or very late 616/36 motor. I should of added this in the original post.
