ImpressIVePower's Avatar
Porsche Crest 912 1969
HI
I need a wiring diagram for 912 1969 the one from 1968 don't show what I' looking for. Or if any body in this forums nows where I connect a black/violet wire that comes off a relay like box located by the voltage regulator. There is another black/violet that the violet are in dots, this is the tacho wire but the other the violet color is a strip on black.
Miguel
Porsche 912E Dual 44 Webers
VW Beetle 1966
Old 07-21-2008, 03:47 AM
There is not a wiring diagram for a 69 912. You have to use the early one and the 69 911 together.
Sometimes a picture helps.
Old 07-21-2008, 07:50 AM
912 1069
Hi Jaems
Here are two pictures
Thanks so much
Miguel
VW Beetle 1966
Old 07-21-2008, 08:24 AM
Miguel, Try the 912 BBS, with the pictures in the help section. There are several 69 912 owners on there and they will be able to help you. I only work on the early cars. There are three different purple and black wires in the 69's 911 diagram one for the tach, one for the wiper motor/switch (same for the 912), and one from the light switch to the small combo instruments cluster.
Old 07-21-2008, 11:36 AM
Cool 912 1969
Jaems
Thanks so much for sending me to the 912 bbs. I found the information there.
Once again thanks so much.
Miguel
VW Beetle 1966
Old 07-22-2008, 06:12 AM
