Windscreen Washer Installation
I am attempting to install a windscreen washer in my 1968 Porsche 912. Got all the parts but no idea on how to connect the wiring or hoses between pump and washer bottle. Can someone send me a photo or describe how this is done.
Thank |
You should try here......more action for this type of issue,
http://www.912bbs.org/index.php Chas. 356912911 |
Thanks Clark, this website was very helpful but nothing on the complete washer hose plumbing from the bottle to the nozzles.
Keowee:
It's pretty straight forward, but it will require a little fiddlin around. First you need to find the wiring to the pump from the momentary (pull) switch which is part of the wiper on/off stalk on the steering column. Then it's just a matter of a.) finding the in/out sides of the pump; b.) connecting up your hoses to the sprayers and c.) making sure there's a check valve(s) in the system. This might help get you started:
Perfect, exactly what I needed.
