-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   40 IDF mixture problem (http://forums.pelicanparts.com/porsche-912-technical-forum/451661-40-idf-mixture-problem.html)
robfike 01-16-2009 01:09 PM
I have a pair of 40 IDF's on my '76 912E. I had a problem with the left carb having the rear cylinder WAY too rich and the forward cylinder a little too lean. The right carb is just fine. All jets and air correctors the same. The lean cylinder would pop through the carb, while I only get about 15 mpg.
I overhauled the carbs due to this problem.
It looks like the problem still is there. Anyone have any ideas?
Carbs are in sync.
maybe368 01-16-2009 04:23 PM
Check that the idle jets are not clogged, this is a common weber problem...Mark
robfike 01-17-2009 06:43 AM
Thanks Mark.
Idle jets are clear, float level is 10mm, new gaskets, etc.
Rob
C. Clark 02-20-2009 11:57 AM
Jetting is a process with Webers, you could try different sizes, but I don't like mixing them up. I went up a size and turned down the mixture, that worked for me, I think I run 55 or 60's, my Webers came with 50 if memory serves.....every cylinder is an individual and has to be tuned accordingly.
best of luck,
Chas.
356912911
