-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Type I engine into 912 (http://forums.pelicanparts.com/porsche-912-technical-forum/469634-type-i-engine-into-912-a.html)
74fj40 04-18-2009 08:55 AM
Hi- I have the oppurtunity to buy a type I VW motor that has been built up completey for a screaming deal. Its a 1950cc with dual webers, bigger cams(not sure what size), HP clutch, lightened flywheel etc.
I've been trying to do some research on putting this motor into a 912 but everything I find is for a type IV.
will this motor bolt up to my 901? can I use the HP clutch, and the lightened flywheel with it as well?
Where can I find more info on this swap?
Thanks! Max
maybe368 04-18-2009 09:18 AM
Look here http://www.912bbs.org/index.php?a=topic&t=18019&hl=type+I if it gives you a trouble page, you need to log in, it is free to join...Mark Just click on the debug info on the error page and the web page comes up...Mark
WFBowen 04-18-2009 05:06 PM
Max:
Check out:
http://www.geocities.com/clarkblumberg/911-912page9.html for some good information.
I've done two of these conversions. The first was a 67S basket-case that we just wanted to get rolling to see how the gearbox/steering, etc. was before a full restoration.
The second is a mildly built dual-port in my current 912 driver. Why? The car was so original that the numbers-matching motor was still in excellent shape and the case had never been split. Since I drive the car daily, it made sense to use a late Type I motor. The benefits are:
1.You can do the conversion without ruining or cutting anything.
2. Some of the benefits are an inexpensive alternator (goodbye antique generator;) direct bolt-in - everything can be reversed in the future; with dual carbs it pretty much looks the same and sounds the same.
3. I've always been a fan of the Porsche 4-banger, but we all know that development of that motor effectively died in '69. Sure, there are some suppliers of hard parts and some racing stuff, but it's pricey for what it gets you. On the other hand, the Type I motor gave birth to an entire aftermarket industry. You can pretty much duplicate the performance characteristics of the Porsche motor with a Type I for a fraction of the price. New, improved cases and heads are cast by aftermarket mfgrs. and any piece you could want is available either stock or heavy-duty/race.
The down side is this: There are numerous companies that manufacture and market sub-standard quality parts, so if you're building a motor, you have to be careful. Also, engine builders vary from legitimate, quality performance builders to "VW" experts who are really kids putting motors together in their back yard (literally) on the lawn.
Anyway, buy/build a T1 with maybe 80-90 hp and enjoy it. You can use it as a reliable daily driver and you won't have to lose sleep if you happen to over-rev it.
Bill.
