Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
beetle engine into porsche- 912 flywheel?
hi guys, i bought a project beetle, with a 901 gearbox in it and have a beetle engine that im trying to fit.
the engine and flywheel fits into the bell housing ok, but the starter wont contact it.
the engine came out of a bay and has the large 280mm flywheel.
ive been told to use porsche starter.
ive also been told to use 912 flywheel.
but i went to look at a 912 a mate of mine has. it has beetle engine. but the flywheel is the same width (280) and depth (37 mm away from engine case to edge of flywheel tooth nearest gearbox)
can you guys tell me something- is the 912 flywheel the same as the type 2(bay) 280 mm flywheel.
is there anyone out there that could help me with this?
ops: :cry:
Old 09-28-2009, 08:37 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
WFBowen's Avatar
I've done a couple 912 to VW conversions in Porsches. Here's what works with a VW motor (TYPE 1) mating to a 901 gearbox:
  • Flywheel: Use a 12v 200mm flywheel which is the stock unit for later Beetles and Bus (to 1971) These are 130 tooth flywheels VW part no. 311-105-273.
  • Clutch/PPlate: You can use any Type 1 stock or performance clutch setup (200mm) just make sure it's the version with individual pressure plate fingers, and not the one with a round collar that engages the release bearing.
  • The throw-out bearing remains the Porsche one.
  • You can successfully retain the Porsche starter motor even though it doesn't fully engage the flywheel teeth.
Old 09-28-2009, 01:04 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
many thanks buddy for your swift reply!! can i ask though- how the hell did his work?? hold on a second............im just thinking...... is the flywheel diameter measured across its widest part ...... or the inner bit where the clutch is??
Old 09-29-2009, 12:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
