Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Member
Throttle linkage Upgrade?
Anyone got a source for instructions on the installation of these packages? I have some parts that came with the car but not sure i have them all and it looks like I will have to relocate the oil canaster and the ignition coil as well as put a hole in the fan housing. If not instructions, pics will suffice, I can figure it out from there. Thanks in advance for any info!
DiNo
'67 912
Old 11-20-2009, 01:30 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
WFBowen's Avatar
Dino:
Isn't that a VW setup? If so, it would be much easier to adapt your current Porsche linkage since the VW crossbar linkage requires a throttle cable coming through the fan housing which, as you mentioned, will require relocation of the oil filter cannister.
Old 11-20-2009, 12:35 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Member
Hmmm....adapt present linkage? You mean using the uninstalled parts I have and just replacing some parts into the already existing mounted brackets and such? It does seem a little crazy to relocate those items just for throttle linkage unless it was already modified. I do think the new would look good either in place of the existing or modified. Thanks for the reply by the way!
DiNo
'67 912
Old 11-20-2009, 01:58 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
WFBowen's Avatar
By the existing setup, I was referring to the stock Porsche linkage which I'm assuming is on your 912. Just to clarify, are you putting a VW engine in the Porsche? If not, why do you want to go to that type of center-pull linkage? I think that you'd be hard pressed to beat the originally engineered design. Even if you need to modify the angles/lengths of the threaded rods which go from the arms of the linkage to the actual throttles, it (IMO) is still considerably easier than re-engineering something like the system pictured.
Bill.
Old 11-20-2009, 07:00 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
