-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   starter fault (http://forums.pelicanparts.com/porsche-912-technical-forum/52450-starter-fault.html)
dimps8 11-19-2001 03:22 PM
starter fault
degreased my engine compartment on the week end using spray can degreaser and light hose off with water, no pressure. dried off ok, lubed all carby joints etc, dried dissy and all electrics. drove car all afternoon.
tried to start on Monday, dash lights worked but no starter motor. waited about half a minute tried again and no problem. solinoide?:rolleyes:
Efrain68912 11-20-2001 12:33 AM
Do you hear a pop when you turn the key?
Efrain
68 912 Coupe
dimps8 11-20-2001 12:41 AM
no nothing! car has a immobilizer but if it is not activated no dash lights come on. they all cam on but starter did not turn???
Efrain68912 11-20-2001 01:06 AM
Probably the solenoid. I've had the same problem with mine. Double check all ground straps, connections, and wiring before removing the starter. Make sure you are getting power to the starter. Also, look into getting a starter regulator (from Performance Products). I'm not sure if Pelican has them.
Efrain
68 912 Coupe
MikeP 11-21-2001 09:38 AM
Is it possible to remove the starter without pulling the engine?
Efrain68912 11-21-2001 12:13 PM
Yes it is - the lower bolt for the starter is a piece of cake to get out. The upper one is a pain. The nut for it sits behind the fan shroud in the engine, so you have to reach over the shroud and feel for it. It should be a 17mm bolt. When you have a wrench on that, then you can remove the bolt from under the car, and the thing will slide out. It helps to have a friend around to hold onto that nut.
Efrain
68 912 Coupe
