Question interior rear-view mirror removal
What's the trick to removing the interior rear-view mirror assembly?
thnx.
Old 11-21-2001, 07:37 PM
Greetings,
You must have the 68' style. It has spring loaded pins that hold it in. It is called a break away mirror. Instead of slicing your scalp away during an accident, it is supposed to break away.
I pry them off carefully with a screwdriver style scraper that I have. The pins are on the left and right sides of the mirror.
Good Luck, JMB
68' 912/5 modified brakes, suspension, limited slip trans, hi-performance engine.
67' 912/5 racecar project
Old 11-23-2001, 08:16 PM
Senior Member
Hello
Just use your hand to pray it out on the arm then the plate has two screws holding it on the roof.
Inserting the base is more interessting you have to use a screwdriver to prload the springloaded plungers.
For practiceing get to the next junkjards looking for old Volksawagen or Vollvo, Saab, Citroen,...
Grüsse
Old 11-24-2001, 05:07 PM
You guessed right- it's a '68. Got it detached, thanks.
Old 11-25-2001, 08:27 PM
Nobody
bob tilton's Avatar
anyone out there have a '68 rearview mirror in concourse or near concourse condition they want to sell?
bob
'68 911L
Old 11-26-2001, 06:48 PM
Question Glued-On Mirror
Does any one know how to remove the rear view mirror mount that is glued to the windshield glass without damaging the glass?? The PO glued the mirror too high and the sun visors hit it every time and I have to reset the mirror. It drives me nuts.
Thanks,
RonD
RonD 69912T
Old 11-28-2001, 10:14 AM
Nobody
bob tilton's Avatar
i have heard of people using heating guns to remove the mirrors from the windshield. might be worth a try. good luck.
bob
Old 11-28-2001, 11:58 AM
