Fuel Pump Question
EDIT: I meant fuel filter, not fuel pump.
After 2 months of owning the '66 912, I guess I can still be called a newbie so here are the newbie questions:
Where is the fuel filter?
Does my '66 even have a fuel filter?
Were fuel filters added by owners by simply cutting into the fuel cord, attaching each end to the fuel filter and then clamping then in?
I see other pictures of 912's and clearly see the fuel pump but I do not think I have one.
Any help is greatly appreciated.
Old 02-26-2010, 06:03 PM
Benzito's Avatar
The filter should be on the rubber hose coming from the left / driver's side of the car. At least on my car, the filter is clear with the paper filter inside. Held to each end of the hose with pressure / screw clamps.
Passed on for other's enjoyment:
1968 912 SWB
1970 914 (with Nov 1969 build date!)
1998 Boxster
Old 02-26-2010, 06:16 PM
The 912 did not come with a fuel filter. Most put one in line before it enters the fuel pump.
Old 02-26-2010, 10:36 PM
that is what I thought....thanks for the advise.
Old 03-01-2010, 05:51 AM
what type of fuel filter in the picture is that? Anyone? (the metal one versus plastic).
I think I would prefer to add that one in.
Old 03-08-2010, 01:36 PM
The Plastic one, when it is dirty, you just replace it. they cost about a dollar or less depending where you purchase. They other type you just clean it and reuse. They run about $4 dollars. Most parts house will care both. The VW bug parts/shops should care both.
Old 03-08-2010, 04:32 PM
