jury's Avatar
Send a message via Skype™ to jury
New Exhaust (sort of)
The rear number plate panel on my car is abit beaten up after various US and UK plates and at some point has had a meeting with something solid and concrete. So Before replaceing it I decided to give this ago. I went down to my local exhaust maker and picked up some offcuts of stainless and some cheapo trim pieces. Afew choice cuts later I'm left with this, I may try getting some slightly longer pieces but I think it looks pretty good, and from what can work out there seems no problems with back pressure etc. I may need that 1720 rebuild though to justify the look
Chris
Old 10-26-2009, 01:58 PM
C. Clark's Avatar
good stuff.....
Chas.
356912911
Old 10-26-2009, 08:22 PM
WFBowen's Avatar
That's a really clean looking modification - & probably where the exhaust should have been in the first place on these cars (IIRC the 911 prototype had a wider version of this and the 911 sport exhaust had a similar exit.)
How does it sound vs. the original pipe?
Old 10-27-2009, 09:58 AM
jury's Avatar
It sounds throatier, and maybe a touch louder. Although I'm certain there are no performance advantages, it is alot lighter than the stock setup.
Chris
Old 10-27-2009, 12:27 PM
Porsche Nut
merbesfield's Avatar
Chris, do you have any sound clips of this exhaust mod? What did you use to determine the spacing? I looks good.
Old 04-15-2010, 07:20 PM
jury's Avatar
The spacing is simply determined by the outlets on the original muffler. I did not weld or cut the muffler, just got some stainless pipe the same internal diameter as the external diameter on the muffler and then put a clamp around. Fairly straight forward
...here is a short video clip, alittle bit cold but you get the idea
Chris
Old 04-18-2010, 08:33 AM
Porsche Nut
Sounds nice. I realized after I made the post the other day that you had probably used the factory spacing. duh. Do the clamps hold tight or do they tend to work themselves loose?
Old 04-18-2010, 09:52 AM
jury's Avatar
Clamps hold fine, these are the type I used...
I also used some exhaust gum/paste to ensure a tight fit
Chris
Old 04-18-2010, 11:48 AM
