rust removal
what is the best rust removel stuff that you guys have found. I have a 69 912 that has a lot of heavy rust that needs to be removed before I can fix it. I also have heard that after you remove it there is a paint that you can get to seal the metal to keep the rust from returning. Thanks
There are several types of rust killer. There are rust removal types that use acid any automotive store would have ether type. Por15 if still available has a system. It really depends on how bad the rust is. The best way is a wire wheel and a dust mask if you just treat it it's still there just covered up.
| All times are GMT -8. The time now is 08:54 AM. |
