Slippery Slope Victim
NY65912's Avatar
Question "Stock" Battery Question
Hi Guys, I want to install a battery in the stock plastic battery tray and also use the plastic battery cover that was originally equipt on my car. Anyone out there using this setup? If so, what brand and model battery is it. Thanks, Mike
MikeČ
1985 M491
Old 12-07-2001, 03:05 PM
wastintime's Avatar
Send a message via AIM to wastintime
Mike,
I actually got rid of my battery cover and strap, but the battery that I'm using now still fits in the plastic try, and is just a tiny bit taller than the battery that was originally in there, so it might work for you. It's a Kirkland 207150. It's got twice the cold cranking amps as the original, and I bought it for about $35. You might want to just measure your battery and then go shopping for a new battery. It doesn't really matter if it's listed as a replacement for the car as long as it has comparable or greater CCAs and will attach to the car. Hope this helps.
Andrew
Old 12-07-2001, 08:56 PM
Efrain68912's Avatar
Any off the shelf battery that fits will work just fine. I use an Interstate. I am hoping to get a super-small Hawker gel cell battery and put it in the smugglers box. After my S suspension. After my Type IV transplant. After...
Efrain
68 912 Coupe
Old 12-07-2001, 09:23 PM
