PCA & MCSCC Instructor
902/14 Gear case
I have looked and looked to find what this gear case is from. It is stamped "902/14". I have not seen this number in any of my books. I know it should be from a 912, and it is magnesium. A '69?
Any help would be great. Thanks, Rob |
Hope this helps:
Helps a bunch, thanks
Rob, what is the serial # on the case? Can you also tell me the casting date xx/68 ?
Dave
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Dave,
The casting # is 901.301.101.2R The serial # is 5091436 I don't know where the date code is. Rob |
Porsche Nut
I have a 902/02. It looks no different than the 902/1. Wonder why the even had different numbers?
The serial # is 5091436 The 901.301.101.2R is the part number not a casting number. The 5091436 "5" I don't know It is not a number from the factory. for the first number there should be only 1-4 "1" would be for a 4 cylinder car, "2" for a 110hp 6 cylinder, "3" for a 130hp 6 cylinder and "4" for a 160hp 6 cylinder. It should be 1091436 The next number "0" says that it is a 4 speed. The next number "9" says that it is a 1969 model year transaxle. The next numbers "1436" Sequential numbering. |
the 902/02 has the 14mm input shaft & the simplified diff AFAIK 5091436 is a good number, thanks. The 5 indicates it was for a 4 cylinder while a 7 indicates a 6 cylinder application; this distinction was from 1969 The 0 indicates it was a 4 speed, 1 for a 5 speed, other varieties also The 9 is for 1969 model year as Jaems says
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 Last edited by djpateman; 04-15-2010 at 10:21 AM.. |
