Removing 26 years of dirt and grease...
As per my previous post I am in the process of reviving a '66 912 after sitting in storage for over 26 years. Going to start this weekend.
I am looking for cleaning product ideas for the interior, exterior and engine as well as any tricks of the trade. -also anything I need to stay away from.
Thanks,
Mike
'79 911 Silver/Red
'66 912 Sun Roof Schwarz/Black
'67 912 Sun Roof Slate Grey/Black
Old 05-07-2010, 10:51 AM
jknapp3's Avatar
We use Var-sol on the old Airplanes we have. (Mineral spirits) with a vacuum type siphon with air compressor. (This is for the engine)
Old 05-07-2010, 01:46 PM
upwardr's Avatar
Do I see a sunroof in there?
Nice looking steering wheel!
Get the tires pumped up and push it outside and give it a wash then some wax and you will feel the excitement.
Looks like a good basis for a fun car.
Larry
1971 911T
1983 Envemo, Cabriolet
1989 Carrera Cabriolet
Old 05-07-2010, 02:44 PM
Thanks Larry!
...yes that is a sunroof hidden under all of the dirt. The previous owner stated it was in working condition when put away -but we will see...
I will take some pics after the wash & wax. Thinking of using Meguiars wax and interior cleaner.
'79 911 Silver/Red
Old 05-07-2010, 06:00 PM
upwardr's Avatar
Looks like you have to keep the cats or racoons off the roof.
Heys my 912 project needs a little help, have the motor rebuilt just need to put it together.
Larry
1971 911T
Old 05-08-2010, 04:10 PM
Beautiful cars Larry. That project looks a lot more realistic than mine! I see you have a sunroof as well. Do you have any idea how to manually open it?
'79 911 Silver/Red
Old 05-09-2010, 02:58 AM
upwardr's Avatar
Have you tried hooking up a battery in the car to see what you get to turn on? Maybe it will work.
I got a small crank hndle with mine that looks like a slot screw driver on one end. This slips into the motor I think and turns the gear mech.
I could be wrong about that but if anyone knows more please chime in.
You have a zippper in the headliner which will give access to the motor and gear drive.
Larry
1971 911T
Old 05-09-2010, 09:26 AM
Thanks I will give it a look tonight. I will also check the tool kit for the tool you describe -however I don't recall seeing anything like that.
Anyone selling an extra sunroof tool?
'79 911 Silver/Red
Old 05-10-2010, 08:02 AM
upwardr's Avatar
Coach House if you would like to be on the email list for the 356, 912 early 911 group send me your contact address it will notify you on up coming events.
We are planning a drive coming up in May.
My email larryupwardr@cogeco.ca
Larry
1971 911T
Old 05-13-2010, 08:04 PM
Porsche Nut
merbesfield's Avatar
Be sure to spray everything, and I mean everything, before trying to works the mechanical stuff. It will be frozen and could break. Lube it up good and let it sit for a few days. What is the condition of the motor? If you attempt to start it you should get some good penetrating lube and spray it in the cylinders, valves and linkage. Don't try to start it w/out turning it over by hand. Don't use WD40, it contains water and is not good.
Old 05-15-2010, 03:32 PM
