Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 912 Technical Forum
1976 912E rear sway bar
Does anyone know if the 912E came stock with a rear sway bar ? If not was it an option ?
I would imagine that the 1976 911 must have had a rear sway bar and would like to think that if I procured one from a 76 911 that it would correctly mount to the 76 912E.
Any thoughts or experience on this ? thanks Dennis
Old 05-29-2010, 06:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Yes, the factory rear stabilizer was an option. Any rear stabilizer from 74 on should work. You will need to buy everything; so it would be best to buy a new rear set. also you will need the factory templates to weld the pieces and the pin in the trailing arm.
There are some after market companies that make rear anti-sway bars.
Old 05-30-2010, 08:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
1976 sway bar
Jaems, thanks, I'll look into it. Dennis
Old 05-30-2010, 08:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
There looks to be a little more to it..................
Check out this posting on the 912bbs.org:
912 Board - Viewing Topic: Transmission Mount Deadweight
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 05-30-2010, 05:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
If you don't want to weld there are kits that bolt on as well ( C-bolt around the torsion tube, etc. )
here's one aftermarket product; Weltmeister has been around quite a while
http://www.weltmeister.com/ProductDetails.aspx?productID=358
Rick Becker
'66 912 since 1977, '68 912 SWT since 1985
PCA 912 & 912E Register Advocate, 912 Registry Member #0001
http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register
Old 05-30-2010, 06:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Sorry, wasn't aware that the 912E carried a 11 lb weight under the transaxel mount. Otherwise any 74-on rear factory stabilizer would of worked.
Old 05-30-2010, 06:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Max Sluiter
Flieger's Avatar
So, why doesn't every owner remove it? I would.
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 05-30-2010, 07:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
912E rear sway bar
Thanks for the help guys. I think I'll look into the Weltmeister kit. Dennis
Old 05-31-2010, 08:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
