What are my RPM's
OK,
Quick, easy question. My tach has even gradations (5) from 2k on up, but only two marks from 1k to 2k. Am I to assume those marks correspond to 800 and 900rpm, and anything lower was not put on the gage? Something different?
Cb
Old 12-19-2001, 12:31 PM
I'm not sure if I understand you correctly, but on a stock 912 tach there are lines every 200 rpm when over 1K. Below 1K there is a light line which is 800 rpm and a dark line under that which is 0 rpm. hope this helps.
Old 12-19-2001, 03:31 PM
