| Registered |  adjustable push rod tubes
			anyone know anywhere other than performance products to get adustable push rod tubes for a 69 912??
|  12-17-2001, 08:29 AM |
| Registered |  push rod tubes
			Hello, Stoddard has them, and I believe there cheaper. Have you ever used them? I'm, curious how they install, etc. www.************* Chas. | ||
|  12-17-2001, 08:41 AM |
| Registered |
			i've used the adjustable ones in a VW baja before.... we were always breaking the stock when the wheel would kick up a log or something.. they work great....
|  12-17-2001, 08:43 AM |
			Hello, So you don't have to pull the engine right? I take it the old ones just unscrew after you remove the lifters, push rods and heater boxes? Chas | ||
|  12-17-2001, 08:49 AM |
| Registered |
			they dont unscrew.. hence the need for an adjustable one...   but yes.. you dont have to pull the motor.. just the lifters, push rods. Not sure yet if i have to pull the heater boxes.... then cut the old one off.. and screw the new one in. | ||
|  12-17-2001, 08:53 AM |
| Registered |
			I've heard that the collapsible pushrod tubes tend to be inferior to the original type ones, and that they tend to leak some oil.
|  12-17-2001, 09:23 AM |
| Registered |
			The ones i had on my VW were actually 2 tubes that slid inside one another with and o-ring to seal between them and spring loaded to seal on the head/block.  The ones i'm lookin at at performace products are threaded instead of spring loaded. I never had any leak problems with the ones in my VW | ||
|  12-17-2001, 09:37 AM |
| Registered |
			If you're going to get them I'd go with Stoddard over Performance Products, Stoddard is a much better company, and their parts tend to be much better than any other mail order Porsche parts places.  I know they have both original and collapsible tubes for sale.
|  12-17-2001, 09:44 AM |
